G Questions
Nothing runs li
05-16-2005 21:19:18
Alright fellas
I just stroked my G. Its a 1938 G... 9 1/2 stroke, and 7.5 Jerry's block.
My budget is blown. What can I expect if I run my old head which is worked over to the max? Also, what cams have worked for people, and what carb mods have worked for people. Also, what are guys doing with ignitions, and adjustments made to clutches for this new horse power.
Help me out.
rstlne
05-18-2005 15:51:52
 Re: G Questions in reply to Nothing runs like a Deere, 05-16-2005 21:19:18
earnie siers(sp) is that your new G???..... was told u had a big one coming.....lol....see ya around....
jd b puller
05-17-2005 15:13:58
What did that crank and block/pistons cost you? i have heard they are pricey. Thanks,
heads...
05-17-2005 05:56:55
Talk to some of the Deere pullers out there. There are some guys who can rework a factory Deere head and it'll work better than one of Jerry's recast ones. They usually flow them, the manifold, and the carb and get everything matched up. I guess what I'm saying is don't just take your head to a machine shop and tell them to port and polish it to the max and put big valves in it. Get someone who really knows what they're doing and it'll be a BIG h.p. difference.
05-17-2005 19:46:51
 Re: G Questions in reply to heads..., 05-17-2005 05:56:55
The guy that built it for me is a machinest by trade. He has did all the work on it, and that has saved me a ton. He has been able to make parts better and better. Im sure he'll do a fine job my the head I have now.
JDGnut
05-17-2005 21:59:45
 Re: G Questions in reply to Nothing runs like a Deere, 05-17-2005 19:46:51
Not sure which head he was thinking... but many have liked the later head over the earlier flat heads... With the right work.... you've got some cubes to fill... Nothing special on the ignition.. MSD, mag pickup.. There are a few distributorless igitions out running.. but I haven't seen any on a Deere... yet.... (also some rules require a Dist or Mag.) On the cam.. just have one ground for your engine.. not one off the shelf... Carb.. I've been happy with mine from Roberts... Good Luck
JDGNut
