Ground speed on H
Red Ryder
05-20-2005 19:44:43
I"ve heard you can put a W4 ring gear and pinion and get more ground speed but I can"t find one. Do you know where to find one or know another IDEA? Thanks for your time.
ChadS
05-21-2005 06:14:44
 Re: Ground speed on H in reply to Red Ryder, 05-20-2005 19:44:43
W4 gears will swap out, and speed you up a little. Another route would be to try a taller set of rear tires. 13.6, or 14.9's are are taller than a 12.4 or a 15.5, the 14.9's are my favorite choice, tall side wall, and they are not all that heavy in weight. I was fortunate to find a W4 gear set, and Im going to try them out this year in my Modified H. Ive had the trouble with being in between gears, and 4th gear is not very strong so, Im speeding up 3rd. Hope this helps,,, Chad
