A John Deere TOO Fast for me!!!!!
Luke
02-18-2002 08:43:00
Hi, I have 41' A John Deere with the two speed transmission instead of the straight 6. I have heard of people slowing them down by taking the 1st reduction gear from a later A and a couple of other parts to fix this. If anyone knows how to do this or can help me in any way I would greatly appreciate it. Thanks, Luke
G Taylor
02-20-2002 20:53:39
 Re: A John Deere TOO Fast for me!!!!! in reply to Luke, 02-18-2002 08:43:00
The two cylinder Deere was built to lugg all day while sipping low grade fuel. Peak HP for fulling at high speed requires another type of engine with smaller cylinders and shorter/larger dia ports.
mike
02-18-2002 11:01:29
I saw one at Sterling, Co pull that had enuff power! It beat 'ol "tuff enuff" of Brooks, not once, BUT TWICE!! Them boys from South Dakata are getting some power out of their poppers!! A G JD beating 460's in the open classes....WOW!!
runningred
02-19-2002 18:20:08
 Re: Re: A John Deere TOO Fast for me!!!!! in reply to mike, 02-18-2002 11:01:29
the g was pulling in div 4 and the 460 is a div 5 tractor the jd's that stay in one piece are short 4 cylinders for div 4
SORRY-it was div 5--460 LOST!!
02-20-2002 06:01:44
 Re: Re: Re: A John Deere TOO Fast for me!!!!! in reply to runningred, 02-19-2002 18:20:08
IT WAS their div 5 deere..and face it, the 460 lost twice!!!!! LOSER!!
Luke
02-18-2002 12:25:55
So I will be fine leaving it the way it is you think?? Just thought while I have it tore down I would slow it down if need be. If not I won't then! Thanks, Luke
mike
02-18-2002 12:42:15
 Re: Re: Re: A John Deere TOO Fast for me!!!!! in reply to Luke, 02-18-2002 12:25:55
how much horsepower are you hoping to make,what bore/stroke,what classes are you pulling in. If pretty much stock motor, YES slow it down! If big bore/stroke then maybe not. Are you pulling any speed classes or mph classes? This JD that whipped the 460 is making a lot of power!
Luke
02-18-2002 17:49:21
 Re: Re: Re: Re: A John Deere TOO Fast for me!!!!! in reply to mike, 02-18-2002 12:42:15
My A will hopefully be cranking 80-90 HP. I have a powerblock w/aluminum pistons, a heisler head and manifold, cam w/lifters, and a late model gas carb.
Greg H.
02-20-2002 10:12:37
 Re: Re: Re: Re: Re: A John Deere TOO Fast for me!!!!! in reply to Luke, 02-18-2002 17:49:21
you might get 55 horse with the changes you've made, but for 80-90 you arn't quite there yet. If it were me, I'd spend all the extra money that you are putting into an early A and purchase a 50-51 model A witht the Straight 6 speed. I guarantee you will have 1500 in alterations and Machine work to obtain 90 Horse. But when you are done, you can go faster and pull more consistantly, but you will have a tractor that is only a pulling tractor. Good Luck in whatever you do. Greg H.
MEAN MOLINE
02-18-2002 21:39:36
ALL THAT MONEY BUILDING THAT AND YOU STILL WILL NOT BE ABLE TO COMPETE AGAINST THE MOLINES!
Gang Green eats Molines for lunch!!!!!
02-21-2002 13:37:58
 Re: Re: Re: Re: Re: Re: A John Deere TOO Fast for me!!!!! in reply to MEAN MOLINE, 02-18-2002 21:39:36
I have seen Gang Green of NC. Beat 6 cyl Molines while running on 1 cyl and backfiring on the other. That is fact. I have seen him beat about everything in his class everytime and it is a 2 cyl. deere.. HA HA. I am not sure the spelling of his name and I am sure some one will know who I am talking about, but just ask Mr. Surles How bad that deere eats that Moline. It may take him twice as long to get down the track, but theres not a time limit.
come back to reality
02-21-2002 13:57:51
 Re: Re: Re: Re: Re: Re: Re: A John Deere TOO Fast for me!!!!! in reply to Gang Green eats Molines for lunch!!!!!, 02-21-2002 13:37:58
ok, play time is over!!
I can tell you haven't seen him pull!!!!!!!!
02-21-2002 15:50:33
 Re: Re: Re: Re: Re: Re: Re: Re: A John Deere TOO Fast for me!!!!! in reply to come back to reality, 02-21-2002 13:57:51
HaHa!!
It's still a Putt Putt
02-22-2002 10:37:09
 Re: Re: Re: Re: Re: Re: Re: Re: Re: A John Deere TOO Fast for me!!!!! in reply to I can tell you haven't seen him pull!!!!!!!!, 02-21-2002 15:50:33
who cares!
Rman
02-20-2002 07:16:35
Your right there, but face it, we can do more with our 2 cylinder than you can with 6. Seen many a 630 and 730 even G beat molines, also seen many a moline whoop a deere too
greg
02-18-2002 19:11:57
with that combo you will not have 80 hp you can change the first reduction gear to slow it down about a 1/3 of a gear. some have got away with only changing the first red gear but to avoid gear wine i would change clutch gear as well or whole clutch greg
