BS question Can I use a stock piston in a briggs..
BS
05-24-2005 06:06:01
Can i use a stock piston while running alcohol? If so what else needs to be done besides the carb adjustments?
Thanks
BS
dan m
05-24-2005 19:11:47
 Re: BS question Can I use a stock piston in a brig in reply to BS, 05-24-2005 06:06:01
yes. you can run less ring gap, more ignition timing,and more compression. if your rules allow. the alky lets you take advantage of these things cause it doesn't detonate as easy as gasoline. but it gets real nasty when it gets pushed to far.
BS
05-25-2005 06:00:02
 what do you mean? in reply to dan m, 05-24-2005 19:11:47
what do you mean by it get nasty if you push it to far?
dan m
05-25-2005 20:13:38
 Re: what do you mean? in reply to BS, 05-25-2005 06:00:02
when alky starts detonating. it really raises the combustion pressure. and it gets real hard on parts.
Ol Gray A
05-25-2005 16:58:56
He means it will go boom!!!!!
BS
05-26-2005 05:57:57
 Re: what do you mean? in reply to Ol Gray A, 05-25-2005 16:58:56
ooohhhh! ok
BS
05-26-2005 06:11:30
 WHAT CAN I DO in reply to BS, 05-26-2005 05:57:57
what can i do about this? I mean is there preperations? THANKS BRAD
buickanddeere
05-26-2005 10:38:27
 Re: WHAT CAN I DO in reply to BS, 05-26-2005 06:11:30
Don't over advance the timing, make certain the mixture doesn't lean out at max rpms and max load due to limited carb/fuel system capacity. That 6 to 1 BS is a bit low to take advantage of the 12 to 1 compression ratio E85 will allow. If you try methyl alcohol it will eat through anything aluminium. Always drain and flush the fuel system with gasoline as soon as the engine cools.
dan m
05-26-2005 19:43:52
 Re: WHAT CAN I DO in reply to buickanddeere, 05-26-2005 10:38:27
don't believe all the crap about methanol being corrosive. i have 5hp briggs engines for my karts that sit all winter in my trailer. in northeast ohio. that i can walk up to blow in the tank and they will light and run just like they did when they came off the track last october. if methanol is corrosive why do some suppliers put it in steel drums?
