Hot farmall
papa smurf
02-18-2002 14:42:31
need tips on how to get 200 h.p. farmall 400
redhead
02-21-2002 20:21:20
 Re: hot farmall in reply to papa smurf, 02-18-2002 14:42:31
Call Lemmons 765-938-1808. If you got the money, they will deliver the hp. Be aware that there are other builders that can do the same or similar thing, but Lemmons is the best and the most reliable. 200 hp is alot for the 248-281 block (and the final CID is much more) and therefore reliability has a dollar value. Good Luck.
JOHN
02-21-2002 07:14:17
Thats easy just put on 40 5hp briggs go cart engines and tie strings to the governers. Well, It sounded good at first.
200hp
03-05-2002 20:37:24
 Re: Re: hot farmall in reply to JOHN, 02-21-2002 07:14:17
call merfield in iowa, for get about 200hp, it's a dream !!!! do you want to pull or just show up.
also do you have 200hp tires and clutch !!!!
only got to go 300 ft get it to the ground !!!
Jim
02-19-2002 08:12:11
It can be done for around $15-18,000. There are a couple of places getting 200Hp on the dyno on Super M's- 450's
man
02-18-2002 17:27:27
3 words 400 small block, well actually it probably can be done get on yahoo and check on some places like lemmon's tractor
can be done
02-18-2002 17:01:32
put 4 motors on it
