Dt414 vs dt436
baystaebinder
02-19-2002 14:53:33
I am making a stock farm class pulling tractor. Is it worth buying a new crank for the 22 extra cubic inches? We are limited on 15% over stock horsepower anyway. But will I get better lugging ability with the bigger cubes or will it really matter and which will make better horse at higher rpm's because we have no rpm limit.
Trapper
02-21-2002 10:22:46
 Re: dt414 vs dt436 in reply to baystaebinder, 02-19-2002 14:53:33
i had a 1066 with a 414 stock and just changed the turbo to a t18 A.R.and got over 250 HP out of it after turning the fuel up to pull
Masseypuller
02-20-2002 10:32:32
Bay State -
So you have apparently given up on the DV550 idea...?
2 cents
02-19-2002 15:44:23
The cheap answer is to put in the biggest pistons you can find and then let it scream.
Brad
02-20-2002 15:56:44
 Re: Re: dt414 vs dt436 in reply to 2 cents, 02-19-2002 15:44:23
Why not go with the 466 crank?
