Got the tranny back together!
ChadS
06-10-2005 16:29:34
Whew! It was HOT today! Nothing like 92 degree temps, to work on and soaked in 80/90 gear oil. But, I managed to get the W4 ring N pinion in, and the entire transmission back together in Something Wilder. PROGRESS!!!! Im into the shifter mechanism now, I got another set of forks, they look real good. man that clip on the lower shaft, at the pto is a ^%#&$*&R*& to get off there! I replaced the entire bottom shaft, and the gears, slider gears too. Soon, real soon. Back on track. ChadS
WILDMAN
06-11-2005 04:59:36
 Re: Got the tranny back together! in reply to ChadS, 06-10-2005 16:29:34
CHAD DID YOU PUT THE HEAVIER BEARINGS IN THE TRANS?
ChadS
06-11-2005 08:03:59
 Re: Got the tranny back together! in reply to WILDMAN, 06-11-2005 04:59:36
Just new ones. The old were a bit sloppy, I took all the tolerances out of the ring n pinion, made it tight, and then set the backlash with one shim. its a whole lot more solid in the parts now, or so it seems, guess that big engine I had, wreaked havoc on that H tranny. Chad
