BUILDING A COCKSHUTT PULLER
KMSD
06-28-2005 16:16:58
My brother has a cockshutt 30 he wants to make into a puller...What type of Mods can be done to the engine for more horse power...Where can you find parts??? I think he wants to use it just for pulling and i think he would like to try for at least 50 HP out of it....
Thanks in advance
Ohio puller
06-30-2005 15:31:19
 Re: BUILDING A COCKSHUTT PULLER in reply to KMSD , 06-28-2005 16:16:58
It's not hard to pull 50 HP out of a 30 and cost isn't bad. If you want a big cube screamer, it won't happen. Find a good machine shop, stroke the crank, bore the block,shave the head, and work the valve train and you'll be in the 50 HP area. Don't go crazy on the head just needs cleaned up. One thing to remember is you have some advantage already with gear speed and selection and to much HP takes that advantage away. The 30's are very competive unless you try to make it something it's not. Parts aren't hard to find with a little time spent on line. I know this was a quick overview and I hope it helps.
Pale Rider 570
06-29-2005 05:08:26
Get on the International Cockshutt Club website, you should be able to get in contact with people who can get you parts.
