How do you port/polish an intake or exhaust?????????
Mr. D
02-22-2002 18:53:34
Looking at a small manifold how can you get a dremel or similar tool the whole way into it or is only the end important? what is a good cutting bit to use; a grinding stone on a dremel flex-shaft??
G Taylor
02-24-2002 08:55:43
 Re: How do you port/polish an intake or exhaust????????? in reply to Mr. D, 02-22-2002 18:53:34
www.extrudehone.com
If you are serious about getting max flow from the externally stock looking intake/heads/exhaust then extrudehone is the only choice. Only the metal restricting flow is removed. Port volume & mixture velocity for ram effect & keeping air/fuel mixed is maintained. Peak HP & bottom end torque are both required. A home hogging out job can reduce HP. Unless you have a flowbench & a solid understanding of fluid dynamics, only matching ports & blending rough edges out of the valve bowl are safe.
Home porting
02-24-2002 08:33:26
Leave the Dremel In the box I used 1/2" drill and A digrinder .
Mr.D
02-23-2002 20:43:40
Yeah im thinkin bout it right now!!!
TODDF
03-08-2002 12:24:41
 Re: Re: How do you port/polish an intake or exhaust????????? in reply to Mr.D, 02-23-2002 20:43:40
third party image
This is a test, I figured it wouldn't bother anybody this far down on the board. Sorry if I bothered anybody--I just have never posted pictures before.
Mr. D
02-24-2002 09:20:27
why did you use my name sir? and you spelled it wrong too, you left out the space between Mr. and D
Brad
02-23-2002 05:57:22
Have you thought about having it extrude honed?
Mr. D
02-23-2002 10:24:42
 Re: Re: How do you port/polish an intake or exhaust????????? in reply to Brad, 02-23-2002 05:57:22
I dont know much about this, what is extrude honed?
Keith G.
02-23-2002 12:19:19
 Re: Re: Re: How do you port/polish an intake or exhaust????????? in reply to Mr. D, 02-23-2002 10:24:42
to over simplify it, extrude honeing is a process that pumps or pushes a slurry of abrasive material thru the intake manifold. thus removing material by abrasion.
Mr. D
02-23-2002 14:42:50
 Re: Re: Re: Re: How do you port/polish an intake or exhaust????????? in reply to Keith G., 02-23-2002 12:19:19
ok thanks
Brad
02-23-2002 05:57:13
