ChadS
07-03-2005 11:36:42
Re: Chads! Update on tuning H with 300U engine in reply to FarmerSid, 07-03-2005 04:46:21
Sounds like you have a 4 weight governor, which could be found on the utility engines. they can be hard to get rpms out of, and, they are a governor that are good for wide open, or idle, not much inbetween. The throttle body I speak of has the idle adjustment screw in the side of the casting, not the flange, when hopping up these style of carbs, it can throw off the idle circuits, and run very very rich. The older carbs like on the M-SM are a better carb to hop up because the idle circuit is a bit better and dont cause erratic conditions. Spring should be loose at idle position, in full throttle, remove the carb bowl, leaving behind the throttle body on the manifold, check to see if the butterfly in the carb is open all the way at full throttle, if not adjust the bottom bolt inside the governor until it does. An H 2 weight governor will get you the rpms and response you need, the newer governors, more common to be 4 weights, are not much for performance in my opinion, something is holding you back,, either the throttle body is shot, or the governor, or both. Chad
