Can anyone here answer some JD powerblock questions
ET
04-10-2001 04:53:45
I have posted this on rummey's board but no one
there has ever run a powerblock 50. I would like
too know what is the compression ratio in a JD50
powerblock its probably simalar to an A. Do I
need to run premium fuel to work it in the field?
How much more fuel will the 50 use with a powerblock in it? I have been told powerblock
engines don't idle very well is this true? I don't
plan on any other modifications than the block
and pistons.
Mike Aylward
04-10-2001 05:46:09
 Re: Can anyone here answer some JD powerblock questions in reply to ET, 04-10-2001 04:53:45
ET, you will raise your compression somewhere around a half point, and you should be able to gain around 5-8 h.p. Your tractor should use no more fuel, but get more results for the fuel you do use. You should be able to use regular gas, and if your tractor idles now it will idle with the Power Block in it. Hope this helps. Mike
