Can't get my tractor running
Farmall H Pulle
07-07-2005 15:12:08
My tractor quit the other day and i can't get it started now all it does is backfires. does enyone know what s wrong with it?
Dick L
07-08-2005 06:45:59
 Re: Can't get my tractor running ( Back To Basics) in reply to Farmall H Puller, 07-07-2005 15:12:08
Is the first thing I do when one pukes is start with a timing check followed with a check to make sure the points open and close. Then sometimes I check the other way around. While I am there check point gap if every thing is turning to the correct location at the correct time. Look for stark both at the points and then at the end of the plug. If every thing looks good there I move to fuel check. Had an 1850 Oliver lose power in the field one time, poped and spit but would idle fine. After two days of checking and rechecking I found the advance weights under the points had seized. Had the carb apart a dozen times or more. Seemed simple after I found it but sure was a pain when I should have been out in the field.
Remember an old saying, at least one that is old to me, when you are having a trouble with an engine problem and you are sure it is fuel it is probly electrical and when your are sure it is electrical it probly is fuel.
Mez25
07-07-2005 17:30:35
 Re: Can't get my tractor running in reply to Farmall H Puller, 07-07-2005 15:12:08
Just had the same problem with my H about 3 weeks ago and i struggled with it for hours. Check your coil, something happened to mine and when i put a different one on it was like nothing was ever wrong.
ChadS
07-08-2005 08:01:26
 Re: Can't get my tractor running in reply to Mez25, 07-07-2005 17:30:35
Is the distributor shaft turning? Ive had the nut come undone and sheer the key in the distributor drive. If it does turn, double check all the ignition components, if you have electronic IGN,,, you may have burned up the pick up in the distributor. Chad
super_m
07-07-2005 15:27:14
could it be the timing?
