How to lose weight on a JD G
Adam
02-24-2002 17:25:29
Could you take parts out(rock shaft.... maybe Second gear?) What light weight parts could you exchange? Where can you get these parts? Thanks Adam
JDGnut
02-25-2002 18:49:37
 Re: How to lose weight on a JD G in reply to Adam, 02-24-2002 17:25:29
How light to you want to get.. and how heavy are U now??? Replace you rearend cover with an Aluminum cover.. Unstyled AL cover weighs about 28lbs... (if its a late G you will have to remount the seat.. or find a pan seat set-up.) ( I don't know where to get one, but look back a few pages, there was a thread about one, here.Got mine from a friend) Lose all of the air clean stuff. (use dry element) Change to smaller front tires and rims.. Get rid of the Roll-matic.. if or get split front pedistal.. find a lower front off a MT/430/420. (get the wheels too.. the center is a little bigger.. the other rims will work.. but the hubs have to ground on a little.. the pedistal will take some work to install. ) Lose the stock hitch frame, and build an adjust adjustable hitch. Pressed wheels on the back..
I looked at removing some of the gears inside.. but you just don't lose enough weight to make it worth the time.. or not having the gear.. I can easily get my G into the 5500lbs class with 18.4x38's... Just some ideas.... Good Luck
JDGnut
