Drawbar Length Height
Smokin Joe
07-15-2005 08:39:18
I was woundering if having your drawbar as short and as high as rules allow, is always the best thing? Does it matter where the chain comes off the eliminator? Thanks for the help.
Lamont
07-16-2005 09:29:19
 Re: Drawbar Length Height in reply to Smokin Joe, 07-15-2005 08:39:18
Unless you are GROSSLY heavy in the front you are better with the drawbar as short and as high as possible. Notice I emphasized the word GROSSLY.
Mopower
07-15-2005 08:48:50
When a drawbar is short and the front end comes up, the hitch height will drop less than a taller drawbar. If you cannot get your frontend to come up, a longer drawbar has more leverage. It depends on your setup. That is my experience, but I run a long drawbar and do best on stoneboat pulling. Our club makes us run a hitch point out beyond the rear tires.
Smokin Joe
07-15-2005 09:12:09
 Re: Drawbar Length Height in reply to Mopower, 07-15-2005 08:48:50
Well this is the deal. I have been pulling a different sled laitly. While runnung a longer drawbar in the past my front never came up, now on the new sled, with a longer drawbar my front does come up. Should i shorten it?
Mopower
07-15-2005 10:00:18
 Re: Drawbar Length Height in reply to Smokin Joe, 07-15-2005 09:12:09
If you can shorten it and still keep your front end in the air just a little, I would do it. The length of the transfer sled chain makes a HUGE difference. There may be some better pullers out there to give advice on this, but if you can lift your front end with the short hitch, it is worth a try.
Case IH
07-15-2005 18:37:51
 Re: Drawbar Length Height in reply to Mopower, 07-15-2005 10:00:18
The length of the chain and the height of the chain at the sled.In seems to me you need to lengthen you,re drawbar to lighten the front end.
