Big Cube Deeres - what carb
bigger jugs
07-15-2005 18:54:38
for you guys with the big cube G's. What are you doing for carb? Looking at some pretty radical stuff for next year. 1200+cubes. How can I feed it?
buickanddeere
07-16-2005 21:16:17
 Re: Big Cube Deeres - what carb in reply to bigger jugs, 07-15-2005 18:54:38
I keep getting the feeling you are a joker rather than serious?
bigger jugs
07-17-2005 06:18:23
 Re: Big Cube Deeres - what carb in reply to buickanddeere, 07-16-2005 21:16:17
Buick. - Dead serious.
buickanddeere
07-17-2005 07:28:38
 Re: Big Cube Deeres - what carb in reply to bigger jugs, 07-17-2005 06:18:23
Do you have deep pockets and a very large milling machine to make a one piece main case/and cylinder block?
bigger jugs
07-17-2005 09:54:38
 Re: Big Cube Deeres - what carb in reply to buickanddeere, 07-17-2005 07:28:38
Nope. One step at a time. Just trying to figure out if I can feed it first.
buickanddeere
07-17-2005 21:22:21
 Re: Big Cube Deeres - what carb in reply to bigger jugs, 07-17-2005 09:54:38
Jerries head, manifold and a modified 51 carb from Roberts is the easiest part of the whole engine buildup. If you want even more flow,send the entire induction system/head to be Extrude Honed.
Juggernaut
07-16-2005 18:59:27
How bout a fabricated manifold and a separate carb for each cyl? Might be a little tricky synchronizing the linkage but a big dog has to eat.
bigger jugs
07-17-2005 06:37:37
 Re: Big Cube Deeres - what carb in reply to Juggernaut, 07-16-2005 18:59:27
I am trying to interpret the rules... I've pulled Div 3 for quite a while but really not that familiar with Div 4. It doesn't look like you can fab manifolds in Div 4. It also says you have to stick with same number of barrels as the original. Doesn't specifically say only one carb? From NATPA Division 3 rules.
12. Replacement carburetors with no modification of carburetor or manifold. Overhang of carburetor to manifold is not allowed. Only stock appearing manifolds are allowed.
from NATPA Division 4
10. Tractors must have the stock engine, frames, transmission, rear end and axle housings or manufacturer’s replacement. Stock heads and their replacements are to remain unchanged in outside appearance. No 7 bolt main blocks in Olivers; no (12) port heads; no 99 heads; no 1600 series heads. AC - WC/WD/WD45 can use D-17 engine; IH - H, 350; M, 450. JD - A/B/G can use power blocks. No M-M 800 heads or blocks. Dual exhaust not allowed except after stock manifold.
12. Any agricultural carburetor allowed. Number of barrels, throats, venture, etc, must be that of the manufacturer for that make and model. Exception: John Deere tractors may run updated (duplex) heads, manifolds and carburetors. Interior enhancement of stock or manufacturer’s replacement manifolds permitted
JDGnut
07-17-2005 09:20:38
 Re: Big Cube Deeres - what carb in reply to bigger jugs, 07-17-2005 06:37:37
Yes, in DivIV-V you can run the Duplex carb... either use the 70Allfuel head.. or Jerry's Machine is making a manifold to run a duplex on the single barrel head... If you run the 70 allfuel head you can remove the center out of the manifold and allow it to draw off both sides of the carb.. JDGnut
Fuel
07-17-2005 10:48:18
 Re: Big Cube Deeres - what carb in reply to JDGnut, 07-17-2005 09:20:38
That's probably the best route to go if the rules where you're pulling will allow it. Cutting the center out of the manifold will essentially give you double the fuel of what it feeds off the factory line, plus you can do a lot of mods to the carburetor.
buickanddeereg
07-16-2005 12:59:29
Block failures and split tractors have occured with blocks relieved less and subjected to fewer HP. How about a custom billet main case/cylinder block?
good point
07-16-2005 21:23:36
 Re: Big Cube Deeres - what carb in reply to buickanddeereg, 07-16-2005 12:59:29
You bring up a good point. A task bigger than getting everythign to swing might be keeping the tractor in one piece. Most of us saw pictures of Shellums G break in two a couple of years back and he was under 1000 cubes.
Nothing Runs Like A Deere
07-17-2005 11:16:56
 Re: Big Cube Deeres - what carb in reply to good point, 07-16-2005 21:23:36
I hear ya! So when I built my G, I fixed that problem. I run a block spacer so you dont have to grind in the crankcase at all to weaken the structure of the tractor. It sets the moto ahead 3inches, some people rant and rave... but I say, "im just being safe!"
C
07-16-2005 11:18:51
Try a kitchen sink.
summit racing
07-16-2005 05:12:56
try a holley 750 dbl pumper, it should be enough, or call Barry GRant.
cube king
07-15-2005 19:36:56
There's only two things I have to say to that...1-I think you're dreaming on the cubes. Maybe you can fool some into thinking it's possible or stir up some talk, but not me, I have built big cube stuff. 2-even if you were able to make it fit, which I HIGHLY doubt, It WILL NOT LAST.
bigger jugs
07-15-2005 20:35:06
 Re: Big Cube Deeres - what carb in reply to cube king, 07-15-2005 19:36:56
cube king- "Don"t worry about the mule, load the wagon." I"ll worry about making it fit and making it last. (Every time it fires)
And yes, "big stuff", you are in the right ballpark on size.
My question was "what can I do for a carb?"
big stuff
07-15-2005 19:56:31
For 1200 cubes you're looking at 8 inches of bore and 12 inches of stroke. You better go billet on the crank! I talked to a guy several years ago who was building one with an 8 inch bore and 10 inch stroke. I'm not sure how he got the block to fit. You'll get to move the cam too.
07-17-2005 11:21:57
 Re: Big Cube Deeres - what carb in reply to big stuff, 07-15-2005 19:56:31
Moving the cam is old news! Shelums do it when they run the 8inch bore.
I saw a G not 2weeks ago that had a 10inch stroke, and "stock" 6 3/8's bore. He ran it on pump gas with a low ratio and was not happy!
Big Cubes Deeres- Contact Merfeld Crank Shop in Pestro Iowa. Say that "Ryan Teach" told you to call. He'll treat you right and really knows his stuff! I mean really knows his stuff! Hes even made some even fire stuff... wicked! He is the guy to talk to, and Jerry's from Jerry's head and block/manifold.
