Goodyear VS Firestone
super red
07-18-2005 11:51:26
What tire would be better for pulling Goodyear Power torques or Firestone field and road?they would be going on a 560
wolfman
07-18-2005 18:55:54
 Re: Goodyear VS Firestone in reply to super red, 07-18-2005 11:51:26
Under 80 hp -Good Year. Over 80, Firestone.
farmall2
07-18-2005 17:47:29
I would quit pulling before I would use Goodyear tires, but every track is different. So use what works in your conditions. Around here(Michigan) Goodyears are always behind Firestones.
Dr.EVIL
07-18-2005 12:50:51
Firestone's.... worn Deep Treads if You can them.
Mopower
07-19-2005 12:34:21
 Re: Goodyear VS Firestone in reply to Dr.EVIL, 07-18-2005 12:50:51
Deep Treads are heavy sons of guns. Ine more lug than Field & Road of same size. I pull Goodyear Traction torques and love how they work when things get loose or there are holes. Otherwise, I would think that the worn deeptreads I have need to be tested on a power track. I might do MUCH better.
Ironman
07-18-2005 14:08:44
Definitely by all means the Firestones. I've seen about every cut possible put on the Goodyears and they still never seem to hook up as good as any of the other brands.
super red
07-18-2005 15:31:41
 Re: Goodyear VS Firestone in reply to Ironman, 07-18-2005 14:08:44
Thanks I will go with the firestone aqnd see how it works.
farmall m puller
07-18-2005 16:32:36
 Re: Goodyear VS Firestone in reply to super red, 07-18-2005 15:31:41
I have a set of 15.5-38 goodyear traction torque tires on my M and dont have any trouble getting them to hook, I run 9 pounds of air in them. I think the firestones are lighter than the goodyears so they might save you a few pounds
CAPT.HOOK
07-18-2005 17:47:34
 Re: Goodyear VS Firestone in reply to farmall m puller, 07-18-2005 16:32:36
true firestone is lighter but i have pulled them both many many times in my experince i have no problems in getting them to do there job i think its the driver and how u understand the track or know how too get them to do there job ty all pullers
