4010 hubs
Chip
07-20-2005 18:47:47
Need a set of 4010 hubs WEDGE type 9 bolt 3 1/8 axle. Has anyone used any other hubs off something like a 2840. Who makes a 10 bolt hub? Thanks in advance!
JD 4010 puller
07-21-2005 20:09:00
 Re: 4010 hubs in reply to Chip, 07-20-2005 18:47:47
I run a set of light M&W 9 bolt's, the 3 u-bolt type like you'd see on a Oliver. I run light, 65-8500lb, and so far so good.
Chip
07-24-2005 19:39:57
 Re: 4010 hubs in reply to JD 4010 puller, 07-21-2005 20:09:00
What are the part numbers on the hubs? M&W 60E30 maybe? Thanks again
JD 4010 puller
07-25-2005 18:46:48
 Re: 4010 hubs in reply to Chip, 07-24-2005 19:39:57
I bought mine used from Special Things, they use to advertise in The Hook Magazine. 513-423-4000, 513-623-9462, or Dengler Tractor 513-423-0706. Unverfirth used to make a good hub, but they don't make them anymore. Special Things had the wedge type too the last time I talked to them.
