Garden Tractor
Kevin
08-04-2005 13:58:21
Im thinking about getting a garden tractor for pulling. Im in NY. What should i look for? Any one know were to get rules. I dont have alot of cash so i dont want to go wild. Can an adult pull in a pretty much stock class?
EFV
08-05-2005 13:17:56
 Re: Garden Tractor in reply to Kevin, 08-04-2005 13:58:21
Where in NY are you ? Find out what club you want to run with,then you can start shopping for a tractor. FYI, like all pulling,start by measuring thickness of wallet. That usually determines what you pull. LOL
mh49
08-05-2005 04:40:34
Kevin,
Most people like any pre-MTD gear drive Cub Cadets because of the shaft drive and the near bullet proof rear end. I would recomend NOT getting what the call a Cub Cadet Original that used a short belt from the engine to the drive shaft. They can be made to pull but it is a pain. If you are going to stay with a (mostly)stock class, a 8-speed Wheel Horse will work well also. Here in Ohio, there are lots of places that run a stock rpm, no cut tire type of class that you can get into for low dollars and be competitive. Then it just goes up from there. :-)
