ChadS
08-10-2005 07:16:28
Re: Coil too hot for points? in reply to buickanddeere, 08-09-2005 22:12:53
Ive had good luck with Accel Super Stock 12v coils. no resistor, and points and condensor. The coil does get warm to the touch, but not extremly hot. I ran MSD a year, and I kept burning up the coil wire, used the fiber wires, not the wire centered, it burned the fiber right off the connection. Caused a miss, I went to wire centered wires, and havent had trouble since. If your coil is getting very hot to the touch, it will short out inside, or if it may have got wet, it may be carbon tracking the distributor cap, You may also check your exhaust valve lash, If your running a different cam, lets say its tight onthe lash, it may run good when its cold, but when it warms up, clearences get tighter and mite hold the valve off the seat just a tad and let gasses escape under pressure. Causing the pop out the exhaust, ignition timing may be off too when this happens,, and cause a double standard. Loss of power, due to an improper timing settings due to the pop that your trying to cure. Also, if the mechanical advance in the distributor is bad, the rotor will do 1 of two things,, 1, either not move at all, or 2, float back and forth freely. #1 is not to hard to fix, but #2 can drive you nuts, it can sometimes stick too far advanced on the timing, and make it erratic, pops out the carb, or the exhaust, on the dyno, you could see the HP fluctuate,, that means the timing is floating around and not accurate. Im betting on valve lash or a leaky valve, or a vacuum leak. You changed everything on the IGN, and it still does it,, Hope this helps, Chad
