Farmall H main jet size
Gary P.
08-14-2005 18:59:58
If I increase the main jet size and the lower metering hole size by 4 drill bit sizes this will be at .070. Will this be in the ballpark?
ChadS
08-15-2005 07:28:03
 Re: Farmall H main jet size in reply to Gary P., 08-14-2005 18:59:58
It depends on which carb you have. Shebler or the OEM Zenith. If your running the zenith, I wouldnt open up the stem sizes that large, just yet, only go 2 bigger on the metering stem, and go 4 on the main jet. that way, your not overdoing it. If you have the bigger shebler, then you could go 4 and 4 on both, that should be sufficient to notice a change in how much fuel can be delivered. The small carb (zentih) is a high vacuum, small throat carb, and a little can go a long way on rejetting them. How much compression does your engine have, and what is the displacement? Other mods? could factor in on what to do. Chad
