Farmall H and M Piston Question
Mark Redman
08-14-2005 20:18:30
Does anybody know if automotive pistons will comply with an H and a M motor? The only things I can think of is the wrist pin will have to be modified and if the piston skirt will clear the rod while rotating. Any help on this matter will be greatly appreciated. Thank you!
ChadS
08-15-2005 07:30:29
 Re: Farmall H and M Piston Question in reply to Mark Redman, 08-14-2005 20:18:30
None that work in stock stroke displacements, auto engines have a very short compression height piston, where the tractors have a very tall compression height. They used to cut and weld rods together to match the compression heights to use car pistons. Havent heard that being done in a while. Chad
