70 POWER
70 PULLER
03-02-2002 07:52:15
Hi fellows i'm new to this post and have a question i have a 1953 JD 70 6.125 bore and 9.5 stroke stock intake & carb head milled just enough to true it up. 80-85hp on m&w dyno tried to work on the manifold and lost all bottom end do any of you have any ideas for more HP thanks in advance.
G Taylor
03-02-2002 09:08:48
 Re: 70 POWER in reply to 70 PULLER, 03-02-2002 07:52:15
If you ground the metal out between the ports in the intake manifold, one cylinder is stealing the others mixture. Purchase an LP manifold & get it extrude honed if port matching & casting flash removal isn't sufficient. A 3" exhaust similar to Gman's G won't reduce low end torque. Torque reserve while lugging the last 10' of track is more important than peak HP anyways.
Jared B
02-02-2006 17:38:59
 Re: Re: 70 POWER in reply to G Taylor , 03-02-2002 09:08:48
I heard from a friend that tried to cut the webbings from the intake manifold and he said that the tractor ran off. I don't know how true this is but I would look into it.
