Rocker Arm Stands for John Deere G
Big G Motor
03-02-2002 19:19:17
I am in the process of building a 48 John Deere G and I'm going to shorten the rocker arms. I've heard that the caps going over the intake valve springs can be left out and you can machine the pocket that they went in off the stand. Can you do this without any problems? Any information is appreciated.
G-MAN
03-04-2002 07:41:12
 Re: Rocker Arm Stands for John Deere G in reply to Big G Motor, 03-02-2002 19:19:17
Is a 70 rocker assembly a direct bolt-in replacement in a styled G?
al
03-04-2002 18:16:26
 Re: Re: Rocker Arm Stands for John Deere G in reply to G-MAN, 03-04-2002 07:41:12
I think yes but changing the towers at most
al
03-03-2002 19:37:42
Yes you can take them off,but I recomend using 70 rockers if you are going to weld cause the 70's are steel G's are cast
