Tire Pressure
phil
03-03-2002 17:30:12
If I lower the rear tire pressure, will the front end get lighter due to the added traction or will the front end get heavier due to lowering the drawbar?
tire pressure
03-03-2002 18:31:56
 Re: Tire Pressure in reply to phil, 03-03-2002 17:30:12
The weight transfer goes down when the tire pressure goes down, so the traction goes down, so the front end goes down, so the length of your pull will go down.
Ind. J.
03-04-2002 19:20:02
 Re: Re: Tire Pressure in reply to tire pressure, 03-03-2002 18:31:56
You can sure tell the guy who signed his post tire pressure doesn't pull tractors much[or if he does he shurely couldn't be doing much winning] We change air pressure at a average of about 2 lbs of air per 1000lbs of weight added. Normaly your hitch height will drop 3\4 to 1" per 1000lbs. if you don't.
SteveV
03-04-2002 16:51:28
Wow! That guy sure has a handle on tire pressure, eh Phil? If I could only think like that I'd win everytime out. Iowa got hammered last weekend with snow...nice to be Arizona huh? Now, seriously letting a little air out of the rear tires probably will not have that much effect on the front end especially if you can counter that by raising the drawbar back to the maximum height or putting a few extra gallons of fuel in the tank for weight on the front. What size tire do you run on your Deere?
Steve
phil
03-05-2002 15:26:15
 Re: Re: Re: Tire Pressure in reply to SteveV, 03-04-2002 16:51:28
Steve, that snow melts away awfully fast when it's about 80 degrees. The tires are 11.2 - 38, new tread. Have a good one.
SteveV
03-05-2002 17:32:08
 Re: Re: Re: Re: Tire Pressure in reply to phil, 03-05-2002 15:26:15
Phil, optimum tire pressure is when the tire fits nice and flat on the track. Too much pressure means the tire is crowned and if you look at the spot where you spun out it will tell you whether you need to add or subtract. Add if the outside of the hole is deeper than the inside...subtract if the center of the hole is deepest. Try starting at about 12lbs and go from there.
Steve
