Allis 226 head Work -HELP
1morgan
08-31-2005 13:37:46
Iam lookig for alittle more power from my 226 c.i.Allis. Does anyone known what I could do with the head. I was told this was and good way to get more with out going any deeper into the engine , and ifso how much h.p. will I get and how much would mite this cost? THANKS FOR YOUR HELP.
meanallis
09-01-2005 09:59:25
 Re: Allis 226 head Work -HELP in reply to 1morgan, 08-31-2005 13:37:46
Acgo valves and seats for an Allis 175 gas engine
will give 3 to 4 more horse depending on how many rpm's you plan on turning. Agco, NOT aftermarket. The Allis 175 uses a 30 degree "knife edge" intake valve. Flows much better than the 45 degree valves used in the WC
through Allis 170. Competition valve job on the exhaust valves by somebody who knows what they are doing.
1morgan
09-01-2005 18:50:06
 Re: Allis 226 head Work -HELP in reply to meanallis, 09-01-2005 09:59:25
HI. Meanallis.with these valves can I use 318 chrysler keepers as was proposed by BushhogPapa. Thanks.
1morgan
09-02-2005 17:11:52
 Re: Allis 226 head Work -HELP in reply to 1morgan, 09-01-2005 18:50:06
Hi Meanallis with these vavles can I use 318 Chrysler keepers as proposed by BushPapa. Thanks.
BushogPapa
08-31-2005 15:51:32
The 226 was pretty "High-Strung" when it was new..at about 1 horsepower per 5 Cu In... For regular Farm use, you could put in a 4 1/8" Power kit with 7.4"1 Pistons... Probably get around or near 50 HP if everything else is in good shape. Maybe someone makes a better cam for them, and some stroke them.. That poor old engine has been Bored and stroked so much from the Manufacturer, that there is not a lot of room left..!! Other than using Chrysler 318 Valve Retainers to increase the spring pressure and a real GOOD Valve Job..it will "do it's thing" anytime you want it to..! Ron.
