Ih (help) wrist pin diameter !!!
BUD BARENIE
03-05-2002 20:31:42
why are there two wrist pin sizes 1.31 and 1"
pulled two motors apart to build one first one had 4-1/8" flat top pistons with 1" wrist pins second one had comfortmatitic domes with 1.31"
wrist pins, was there a vibration problem!!
is there a weight difference !!!!! pulling , working on a rebuilb
farmall flogger
03-06-2002 09:17:07
 Re: ih (help) wrist pin diameter !!! in reply to BUD BARENIE, 03-05-2002 20:31:42
The M and Super M motors had the 1.310 size pins. The 400-450 motors had the 1.0 pins.
randy hall
03-06-2002 17:02:27
 Re: Re: ih (help) wrist pin diameter !!! in reply to farmall flogger, 03-06-2002 09:17:07
ih had some trouble breaking the skirt on their aluminum pistons so they went from 1 5/16" pin to a 1" pin. they have a set of thick walled piston pin bushings so you can still use your old rods. the part number is 367128r92
