435 Deere puller
4010 puller
09-26-2005 19:59:42
Guys:
I'm wanting more info on these tractors for pulling. Do you have any contacts of anyone who has pulled these things competitively? Any photo's?
Thanks,
John
antique puller in wi
09-27-2005 14:57:39
 Re: 435 Deere puller in reply to 4010 puller, 09-26-2005 19:59:42
There is one that pulls in our area occasionally. I don't know a whole lot about it but I can give you the rumors and the little bit that I have seen. Injectors out of a "silver 92" Detroit, probably too much fuel, he has talked about getting taller gears to spin the blower faster. One small (50#?) weight 5' out front, (yes, feet, legal in brush pulls). Has given my G fits from time to time in 6000#, 6500# semi-stock (similar to Div. 2, no cut tires). He reports 60 HP on the dyno.
Thats all I know
buickanddeere
09-26-2005 21:01:24
Check the search function on this pulling site for "435".
Unknown Puller
09-27-2005 06:22:40
 Re: 435 Deere puller in reply to buickanddeere, 09-26-2005 21:01:24
An issue or 2 back there was one on the front cover of the HOOK mag. His name and home town should be inside the front cover. I believe he pulled at Tunica, MS. on Friday, last year.
buickanddeere
09-27-2005 09:59:02
 Re: 435 Deere puller in reply to Unknown Puller, 09-27-2005 06:22:40
You will have to either use 38" rims or strip it down into a 4000lb class where a Massey 44 with 38" rims can't go.
CLIFF S
09-27-2005 16:52:29
 Re: 435 Deere puller in reply to buickanddeere, 09-27-2005 09:59:02
Theres two that pull in central Pa a Father and Son and the Sons 435 get in to 3500lbs class and they both do well and the father pulls up to 5000lbs
