H Farmall vs. 300/350
redcub
09-27-2005 15:15:06
Why don't you see 300s or 350s pulling very often? Is there a disadvantage to keeping this block in the original chassi verses putting a 300 block in an H? What can you get a 300 down to in weight with stock wheels?
Don Mc Cartney
09-28-2005 12:22:44
 Re: H Farmall vs. 300/350 in reply to redcub, 09-27-2005 15:15:06
I have both 300 and H stock pullers.Both tractors run about 40 hp. I pulled the H in 4500 class, the 300 in 5500 and 6500 lb. class. The low speed of the t.a. makes all the diff. in the world. I pull aginst IH M, John Deer A, Oliver 88 WC45 with a six cylinder engin, Am in the top 2 most of the time. With the 300 you will have lots of fun.
Dave in MN
09-27-2005 16:26:58
My son has a 300 that he pulls in the 4500 stock and open classes. It would have to be an extremely hot H that would have a chance to run with him or the 88 olies, or the 101/44 masseys. The TA in the 300 is a huge advantage. By the way, I have a stock Super H that I pull in the farm stock classes. It would be embarrassing to pull that tractor in the stock/open classes. I suppose that anything can be made competative with enough money spent on it.
Kevin
09-27-2005 16:08:11
I dont know much bout the 300/350 but i have a stock H i pull in 4500, and i know of a stock 300 with a wide front that pulls 5500 with no weights.
pcy1066
09-27-2005 18:52:00
 Re: H Farmall vs. 300/350 in reply to Kevin, 09-27-2005 16:08:11
we have a 300 gas with a turbo with 18.4x38 on 18 inch wide wheels we pull 4000 lb feild stock with , we also do a little dead wt pullin with it, 4000-5500 lb at 4000 it will carry 4 75 lb ih wts with my son who weighs 250 we are guessing something around 85-100 hp at 20 lb of boost
redcub
09-28-2005 10:17:45
 Re: H Farmall vs. 300/350 in reply to pcy1066, 09-27-2005 18:52:00
What piston set up are you using? What bore/stroke. How difficult is it to put on the turbo?
pcy1066
09-28-2005 19:24:09
 Re: H Farmall vs. 300/350 in reply to redcub, 09-28-2005 10:17:45
st bore and stroke , low comp pistons, set it on just like you would a dsl, 6060 allis to4, blowing thru the updraft carb with 806 bottom on it, about 200to 225 feet it was running out of gas , blue holly fuel pump, line tead with kinsler fuel injection nozzel in hole above carb, electric shut off valve to nozzel , around 200 ft turn it on , valve springs, and a button clutch and new ta
