Bore it out?
SB
03-07-2002 15:26:52
i have a late 50 deere A and want to know if i should bore it out, i have never puylled it and am getting ready to put it back together, i am going to get a new radiator and a big nut g carb. i plan to pull dead weights every week and pull live weight at the local and surrounding fairs. should i bore it out now or wait and see, hgow hard is it to bore one out with the whole tractor together? thanks shohn, rushville, IN
52 A Boy
03-19-2002 19:09:29
 Re: Bore it out? in reply to SB, 03-07-2002 15:26:52
I have a 1952 JD A and its stock engine and i have plenty of power with that creeper gear, so if you have the creeper gear i wouldn't. You will spin out before you power out.
Hope this helps.
52 A Boy
BJ
03-09-2002 15:49:57
I made the same mistake also couldn't figure out why someone would want to go back to a single barrel carb. over a duplex
G Taylor
03-08-2002 19:51:51
How many cubic inch & HP will be gained by overboring a stock block? How are you going to attach a big nut carb onto a duplex carb manifold?
dyslexic G Taylor
03-08-2002 19:54:09
 Re: Re: Bore it out? in reply to G Taylor , 03-08-2002 19:51:51
Made a mistake, thought at first it was a model 50 not a 1950 model "A".
