HOW TO DETERMINE IN OUT TURBO SIZE???
jd diesel pulle
10-03-2005 11:32:06
IS THE TURBO SIZE IN AND OUT MEASURED ON THE PLUMBING (PIPING FOR INTAKE AND EXHAUST MANIFOLDS) SIDES OR THE TURBINE SIDE OPENINGS. I HAVE A GARRETT TURBO WITH THE NUMBERS STAMPED ON THE CASTING THAT ARE A/R.75 M24. I DO HAVE SOME OTHER NUMBERS IF NEEDED. CAN ANYONE SHED SOME LIGHT ON WHAT SIZE TURBO THIS IS? ANY HELP WOULD BE APPRECIATED.
buickanddeere
10-03-2005 19:34:18
 Re: HOW TO DETERMINE IN OUT TURBO SIZE??? in reply to jd diesel puller, 10-03-2005 11:32:06
Link
856uller
10-03-2005 17:41:45
in our club the turbin wheel must extend 1/8" in to the housing at the max size for the class. all air must go thru the wheel at that point. exhaust is the same there is also a size for the foot. i try to find something to fit into the bore on both sides than measure it. it is the inside that matters.
