Removing a dry sleeve held with sleeve retainer
Mike
03-09-2002 17:05:16
I need to remove a dry sleeve out of a Farmall 350 block. It was installed before with sleeve retainer and I cant move it now. I warmed it up with a torch and that didnt help. Any idea's?
randy hall
03-09-2002 19:01:55
 Re: removing a dry sleeve held with sleeve retainer in reply to Mike, 03-09-2002 17:05:16
weld about a dozen passes up the sleeve quickly so you don't burn thru and it will shrink the sleeve.
Bill
03-09-2002 20:17:56
 Re: Re: removing a dry sleeve held with sleeve retainer in reply to randy hall, 03-09-2002 19:01:55
This works very well we also try to weld a couple of piles 180 degrees apart at the top inside the sleeve this will give you a good place to drive on
