JD G That broke in half at Lincoln
John Crawford
03-09-2002 20:27:31
Does anyone have any pictures of the G that broke in half? What caused it to brake in half?
A man
03-10-2002 06:09:14
 Re: JD G That broke in half at Lincoln in reply to John Crawford, 03-09-2002 20:27:31
Do they make a crank for a Ajd like that wonder what it would cost Where do you get it.
JDGnut
03-09-2002 22:13:17
There was one pic on the Hook mag, bit it didn't get to detailed.. some tractors all also carved out to lose a few lbs.. some for the big rotating assemblies.. JDGnut
G-MAN
03-09-2002 22:05:58
Seems like a waste of a lot of time and money. I heard that the crank in that tractor was worth $7500, is that possible? Probably just a rumor.
G Taylor
03-09-2002 21:07:07
Far more power/stress than stock carried by castings partly milled away to clear larger internal components. Must have been one suprised driver, just fortunate no one was seriously hurt.
GangGreen
03-09-2002 21:00:49
The G that broke in half at Lincoln i beleave had a Jerry's block on a Jerry's block you have to cut the case out so thin by the front of the clutch that you have to put a plate back over it. I think that is what happened.
yort
03-10-2002 15:19:15
 Re: Re: JD G That broke in half at Lincoln in reply to GangGreen, 03-09-2002 21:00:49
I was told it was a kansas block. Are they the same?
JDGnut
03-11-2002 10:19:00
 Re: Re: Re: JD G That broke in half at Lincoln in reply to yort, 03-10-2002 15:19:15
Jerry's machine shop is in KS.. they are the same... JDGnut
JD G GUY
03-10-2002 14:07:31
im suprised about that, it must have been really scary to have the thing break in the middle of a pull. its a good thing that everyone was ok
