AC WC/WD in the 5500 with 38 wheels???
Agco Avenger
10-16-2005 19:59:57
Question: Is the transmission and rear end of a WC or WD strong enough to pull 5500 stock classes on 38" wheels without breakage? I have a small stroker motor that I have been thinking about putting in a stocker and pulling 3500-5500 if the drivetrain will take it. Never pulled an AC heavier than 4500 so far. Thanks for advice. Avenger
rmwsd
10-17-2005 01:22:41
 Re: AC WC/WD in the 5500 with 38 wheels??? in reply to Agco Avenger, 10-16-2005 19:59:57
it will pull 7200 with no problems my buddy has done it i pull 5200 with mine i have pulled as much as 5850 no problems
Flogger
10-17-2005 07:40:03
 Re: AC WC/WD in the 5500 with 38 wheels??? in reply to rmwsd, 10-17-2005 01:22:41
That was a pretty nice armload of gold you carried off sat rmwsd.... Good to see you boys again...
rmwsd
10-17-2005 08:31:32
 Re: AC WC/WD in the 5500 with 38 wheels??? in reply to Flogger, 10-17-2005 07:40:03
why thank you sir i think you had a pertty good load yourself sure was good to see you also hope to see you back more often
770 Puller
10-17-2005 12:28:03
 Re: AC WC/WD in the 5500 with 38 wheels??? in reply to rmwsd, 10-17-2005 08:31:32
Round Man, did you turn it up at the pull Saturday? Pinky and I both did! RPM check from hell.
BG
rmwsd
10-18-2005 02:18:20
 Re: AC WC/WD in the 5500 with 38 wheels??? in reply to 770 Puller, 10-17-2005 12:28:03
i heard yall had a lot of fun with them rpms mines still stock no need to turn her up works fine like she is
AO
10-17-2005 12:01:31
Did ya'll notice the MM with the ORANGE motor? I knew we could turn him if we stayed with it! Hey Flogger it was real good seeing you! I didn't know if I'd make it Saturday. Had a pretty good day too! I'm just not sure about the Oliver with the fuel tank on the rear under the seat!?
Flogger
10-17-2005 14:05:56
 Re: AC WC/WD in the 5500 with 38 wheels??? in reply to AO, 10-17-2005 12:01:31
I did ask the Red Hoss if that was a pony keg of Bud Light out in front of his steering wheel... Looks like a pretty wicked tractor once he gets all the little details worked out
LW
10-17-2005 17:20:24
 Re: AC WC/WD in the 5500 with 38 wheels??? in reply to Flogger, 10-17-2005 14:05:56
I do I need to come pilot the machine?
Flogger
10-18-2005 06:12:04
 Re: AC WC/WD in the 5500 with 38 wheels??? in reply to LW, 10-17-2005 17:20:24
I think the Red... uh Yeller Hoss will probably be okay once he gets used to the power and speed. Kinda like stepping off a tired nanny goat and on to a thoroughbred race horse.
Screamer AC
10-18-2005 10:12:46
 Re: AC WC/WD in the 5500 with 38 wheels??? in reply to Flogger, 10-18-2005 06:12:04
Don't you mean Mule (Mini Muline)
AO
10-17-2005 16:34:48
I don't know if Judy would allow a pony keg. We did change his name to the "PRAIRIE DOG", in honor of his new colors.
