Fuel octane aditives ????? HELP
1morgan
10-25-2005 16:20:58
Does anyone known of any fuel aditves I can use to make 93 octane go to say 105 -110. My compression is around 10.5 -11. to 1. THANKS 1MORGAN
buickanddeere
10-26-2005 11:00:41
 Re: Fuel octane aditives ????? HELP in reply to 1morgan, 10-25-2005 16:20:58
Straight 100LL or E85.
ChadS
10-26-2005 11:45:43
 Re: Fuel octane aditives ????? HELP in reply to buickanddeere, 10-26-2005 11:00:41
E85 and pump gas. Thats the best fuel you can get for the $$$$$!!! Try it, youll never look back. Ethanol,, there is not much to be known,, not many use it, know much about it. Its mixture is relitive to the compression pressure in your engine. Also depends on make and model as well. ChadS
4 cylinder puller
10-27-2005 01:33:46
 Re: Fuel octane aditives ????? HELP in reply to ChadS, 10-26-2005 11:45:43
We run 110 octain in our puller with 225 lbs of compresson. Would like to know more about E-85 as there is about $2.00 difference in price per gal.
ChadS
11-04-2005 09:50:25
 Re: Fuel octane aditives ????? HELP in reply to 4 cylinder puller, 10-27-2005 01:33:46
Its a low rpm fuel, has to be mixed with pump gas to run correctly, compression pressure determines the mixture percentage. At 225, you can mix 1 gallon of 93 octane, to 1/2 gallon of E85, you could run up to 50/50 mix, but may sound like an alky burner with a huge cam. It will burn cleaner than any other fuel, so plug color can vary, the pump gas will give it the plug color, but will be a light brown in plug color after a workout. Chad
1morgan
10-27-2005 18:57:54
Iam running aviation fuel at 245 psi. and my engine will deiseil also, not sure if I should run 110 racing fuel? I run AV. fuel also for the lead. 1MORGAN.
G/MAN
10-26-2005 10:30:34
By the time you buy the gas and the additives to jazz it up that much, it would likely be cheaper to buy race gas of the proper octane rating.
JaredM
10-25-2005 18:05:36
You could try adding ethanol. I think it has an octane of 115 but I don"t know much else about it.
super a puller
11-02-2005 11:43:51
 Re: Fuel octane aditives ????? HELP in reply to JaredM, 10-25-2005 18:05:36
the octane of ethanol using r+m/2 is 113 octane.
