???? for 44 massey engine builders
44 puller
11-03-2005 11:45:10
I've been pulling a 44 for about a year and want to stroke it.I bought a block from a guy that has been bored and dry sleeved to 4-3/8.My question is what rod to use if I offset grind the crank and stroke it a 1/2 inch?What piston would you recommend.I've looked at some automotive stuff but haven't found anything 4-3/8.Any ideas are appreciated.Eric
Masseypuller
11-04-2005 05:28:48
 Re: ???? for 44 massey engine builders in reply to 44 puller, 11-03-2005 11:45:10
Use the stock rod with a 6" stroke. Either machine 0.25" off of the piston or have the cylinder head counterbored 0.25" to accept the protrusion of the piston.
Counterboring the head is the method that I have used in the past and has the added benefit of reducing the "static" chamber size (further increase in compression ratio)...
Regards,
Masseypuller
Doug Boll
11-03-2005 11:49:37
870 Case Gas, kind heavy and might be too long for a stroker, Work good in my CC, 477/534 ford 4.5, should be some performance automotive close
