Cast Wheels or Pressed Steel ????
46 JD Model A
11-16-2005 14:50:14
My operators manual reads....NOTE: Cast disk wheels approximately 250 pounds heavier than steel wheels.....does that mean 250 lbs.(per wheel) for a total of 500 lbs. per two on the tractor?? Thanks, 46 "A".
Drew
11-16-2005 15:19:53
 Re: Cast Wheels or Pressed Steel ???? in reply to 46 JD Model A, 11-16-2005 14:50:14
On mine it was 500lbs for the pair.
46 JD Model A
11-16-2005 17:43:08
 Re: Cast Wheels or Pressed Steel ???? in reply to Drew, 11-16-2005 15:19:53
Drew,
Thanks for the information.....now either me or the tractor has to find a way to lose another 80 lbs. That should get us into the 4500 lbs. class.
Drew
11-16-2005 18:05:39
 Re: Cast Wheels or Pressed Steel ???? in reply to 46 JD Model A, 11-16-2005 17:43:08
Email me with what all you have done so far and I can get you the 80lbs if not more. Your rules will dictate how easy it is though.
