ChadS
11-30-2005 10:41:53
Re: Chad s m? in reply to SUPER MTA PULLER, 11-30-2005 10:27:14
Wilson machine, Gary Baker, maybe, Paul Marlatt,,, The copper head gasket will work without the rings, or with them, as long as the block has been machined with the rings to make it flat for it to seal up. As long as you have the clearence on the pistons and the head, you can pick up 5hp from the compression increase. Stock is around .072 thick compressed,,, Probably around 10-15 psi more with a 30,, a 450 gasket will seal up a M block, without the rings, you can mill the head down a bit and pick up from where the groove leaves behind, but the rings would be helpful in keeping the compression pressure up. Gotta be milled flat to use copper,,,,, if not, it will leak water in the oil,, will seal the cyl,,, but not anywhere else. Chad
