ChadS
12-05-2005 07:23:43
Re: 450 cam in a super m in reply to DWV, 12-04-2005 13:44:15
I would like to see that info when you find it. if you would, could you email a copy of the ad? I have been told, that some of the early Super M"s retained the old M camshaft, along with the 8060 head,,, I have not seen this yet, I have not had a very early 52 SM in to really know if that is accurate, but I would not doubt it if that did happen back then,,, Im wondering about why they upgraded the cams once more after the inital change to the Supers,,, I would suspect, that the cam gear kept comming apart in the fields,,, would IH have recommended to replace the cam with the new style cam, as far as it being a left hand thread on the nut,, I have repaired several SM-SMTA tractors that had the cam nut come off, and the gear break teeth off,,, when orderd parts for that tractor,, they sent the left handed cam,,,, Is it a repair bullitin you have, or is it a option ad? Chad
