HOW much V-8 in W D
1morgan
12-05-2005 18:02:22
Does anyone known how much a W D Trans. Rear end etc. take. How big a V-8 ???
buickanddeere
12-06-2005 16:03:22
 Re: HOW much V-8 in W D in reply to 1morgan, 12-05-2005 18:02:22
As long as torque is kept to no more than maybe 1-1/2 to 2 times that of the factory engine. And no suddent jolts/shock loads are applied. You can go as high with the rpms and HP as you want until centrifical force becomes an issue.
Hurst
12-05-2005 19:33:41
For a 350 making 375 horsepower and 420 ftlbs of torque, I think it was something like a max of 2 times the torque of the 226 in a WD45. That was just and estimate. What are you planning on using the tractor for? If it is just gonna be a fun tractor to drive around going 45 (which it can do if it is hooked up directly to the tranny and you have the engine going at a little less than 6000 rpms) then the rear end should be fine torque wise, that is where revolutions come into play. I don't think that it will hurt anything, but I have never done one. Look down below at the bottom of this page at V8 Allis and one of the posts has the number and name of a man who has done several of these. Good luck
Hurst
