HOW FOR TO STOKE
B GREEN
12-14-2005 07:23:20
HAVE A 41 JD B HOW FOR CAN YOU STROKE BEFORE HAVING PROBLEMS WITH CAM SHAFT IN YOUR WAY THANKS
B GREEN
12-16-2005 06:07:43
 Re: HOW FOR TO STOKE in reply to B GREEN, 12-14-2005 07:23:20
THANS SO FOR BUT WHAT TRACTOR OLIVER RODS ARE YOU USING OR FARMAL RODS. I WAS THINKING OF USING 6030 JD PISTONS THEY ARE 4.75 INCHS AND HAVE A SET OF THEM LAYING HERE FROM A DIFFERENT PROJECT. WHAT DO YOU THINK OF THAT. THANKS
jd b puller
12-15-2005 14:45:50
B Green: WTW has 2 good running B's. Just adding a little on what WTW stated. The Farmall rods (2.25 or 2.3) work well, but I like the bigger journals of the Oliver rods. (2.56") On the '41, you can go to 7" with 2.56" journals and almost no grinding. Whoever does your crank, either send him your cam or get a different one, but either way, have it "slabbed" for clearance. Don't let them just chuck it up in a lathe and turn the diameter down. Like WTW said, 7.5" is getting more common, but a lot more work. Your oil lines to both mains will be in the way but easily altered and you will need to poke holes in the back of the case and a little on top. The 2.56" journals are bigger, stronger, and actually clear better than the Farmall rods.
If what you meant was, how far do you have to go before MOVING the cam, it must be somewhere more than 8", cuz mine hasn't moved.
Also, keep in mind that the guy that makes your crank, rods, cam, etc will have a lot to do with how much grinding you will have to do. Everybody that has made cranks has had at least one break, and everyone has good and bad personalities and levels of knowledge about clearancing things and fabricating them.
WTW
12-15-2005 13:20:04
It all depends on what connecting rod you use and how small of a rod journal you are will to run. You can get to 6.75 with a special rod and not have to do much grinding if any but you will be running a 2.25 rod journal to achieve this amount of stroke. If the crank is done right it will live with this size journal and this amount of stroke. Not all that big of stroke these days for a "B" but it would make you a good 3 mph tractor. 7.5 stroke is fairly common these days and they are some bigger than that. Plan on getting some new grinding stones for the shop if you are going anywhere near that dimension. Good Luck, DW
