Help on farmall 400
Farmall 400 pul
03-13-2002 16:27:23
I am 19 years old and have been collecting and working on tractors since i been able to walk I bought a farmall 400 and stripped it to about 4900 pounds.In the motor it has a 281 cubes with a 60,000 volt coil and 110 octane gas. I am planning on pulling the 5500, 6500 pound class. Can any body that pulls farmalls give me some advice on what I can do to make the tractor pull better. Also it has 16.9/38 armstrong tires on the tractor what gear can i pull the tractor in.
Dan
03-15-2002 11:52:28
 Re: help on farmall 400 in reply to Farmall 400 puller, 03-13-2002 16:27:23
Depending on the track if it loose I go up with the ta and if the track I pull it down otherwise I will run out of power faster.I tried pulling with trans in second but it seemed to run out of power early.
Dan
03-13-2002 19:14:50
I pull with a 400 with 281ci. I don't know weather you have a fast hitch or not . I changed to a standard drawbar and shortened it to rules of where I pull. Helped alot. I pull in first and low with the TA . Tractor pulls very well at 7000lb and 8000lb class.
Farmall 400 puller
03-14-2002 13:49:47
 Re: Re: help on farmall 400 in reply to Dan, 03-13-2002 19:14:50
Dan what gear can i pull in the 5500, 6500 pound class and I made my own draw bar hitch to 20 in high and about 24 from center of axle.
RedFred
03-15-2002 07:23:29
 Re: Re: Re: help on farmall 400 in reply to Farmall 400 puller, 03-14-2002 13:49:47
you can try 2nd and if it starts to puke - pull that torque!
TP from Central PA
03-15-2002 12:04:44
 Re: Re: Re: Re: help on farmall 400 in reply to RedFred, 03-15-2002 07:23:29
Put the coon-tune on that C-281 and you'll be able to run second, no problem!!! Those IH four cylinders amaze me, the torque and Hp you can get out of them is wild!!!
Farmall 400 puller
03-16-2002 07:12:51
 Re: Re: Re: Re: Re: help on farmall 400 in reply to TP from Central PA, 03-15-2002 12:04:44
what is coon-tune that i can put to my 281 cubic in motor
Mark
03-15-2002 22:23:31
What is the special coon tune?
