Oliver 66, to much compression!! HELP
Willie
03-13-2002 21:02:34
Have an oliver 66 with oliver 88 sleeves and M&W high dome pistons in it and the crank is stroked 1/2 inch from stock. Had it running on straight pump gas and it knocked like a diesel. It turns out that we had 255 lbs of compression. My question is, how do you know how much of the dome to shave off to get around 190 - 200 lbs of compression? If you shave off to much then you are screwed. I would appreciate some good input here.
Tim
03-14-2002 14:34:03
 Re: Oliver 66, to much compression!! HELP in reply to Willie, 03-13-2002 21:02:34
Sounds like you have what you need. You can buy pump fuel at certian stations that is high octane.
112 or 116, something like that. You could cc the dome and cc the head then go search the internet for one of the free calculators. You have to know the exact bore and stroke, deck height, combustion chamber cc and maybe compression height on the piston.
It would be eaiser to change gas, plugs, timing and maybe add water.
Big G Motor
03-14-2002 10:08:16
Call Tilley...
Scared of another Oliver
03-14-2002 11:57:23
 Re: Re: Oliver 66, to much compression!! HELP in reply to Big G Motor, 03-14-2002 10:08:16
Sounds like Tilley has scared you boys to death!
88 MAN
03-14-2002 16:36:41
 Re: Re: Re: Oliver 66, to much compression!! HELP in reply to Scared of another Oliver, 03-14-2002 11:57:23
Does Tilley have everyone running scared? He's tractor seems to be running great! Looks like he really Knows what he is doing! Hope he comes to Columbia!
he has no idea what he's doing!
03-15-2002 08:17:24
 Re: Re: Re: Re: Oliver 66, to much compression!! HELP in reply to 88 MAN, 03-14-2002 16:36:41
Then why is he WINNING!!
03-15-2002 14:34:34
 Re: Re: Re: Re: Re: Oliver 66, to much compression!! HELP in reply to he has no idea what he's doing!, 03-15-2002 08:17:24
88MAN
Rich B
03-14-2002 05:14:46
Do you have the option to run any other fuels?AV gas or VP.let me know E mail if you like.had a similar problem with my 88. Rich B
