560puller
carlisle
12-29-2005 01:37:15
need help and info on building a 560 pullin tractor. I bought 1 4 a thousand dollars and have been pulling it sum but i cant keep headgaskets on it cuz of the turbo. i also need info on gettin more fuel and air 2 it, ive had the pump turned up 2 the max and 3 governors taken out what can i do 2 make it better without spending over acouple thousand
JakeF
12-29-2005 20:16:48
 Re: 560puller in reply to carlisle, 12-29-2005 01:37:15
Does ARP have a listing for studs on a D282 or do you have to special order them? Any idea on the price. May look into them when I do the headgasket on dads 660 turbo.
Drew
12-29-2005 18:59:58
On the headgasket issue: First off, make sure the head and the block are FLAT. If they are flat, I would O-ring the block and have reciever groves cut into the head and use a copper headgasket. A set of ARP studs will help you clamp the head on better too. That stud kit isnt the cheapest thing in the world, but its cheaper than what can happen when a headgasket lets go.
ras sch pony express pt g
12-30-2005 18:24:46
 Re: 560puller in reply to Drew, 12-29-2005 18:59:58
YOU MEAN THERE ARE STILL COCHSHUTS LEFT AFTER RALPH AND THE BOYS CUT THEM ALL UP. WE WENT THROUGH 14 IN 1976 PERSONLY
