TIRE SIZE
DAWI
12-29-2005 14:12:05
Can any one tell me what a good tire would be to put on a case VAC with a 201 combine motor. I would like to stay in the 28 inch size. But a taller 28 inch tire like a 14.9. Because the Vac rear end is very close to the ground.
Bob in Wi
12-29-2005 17:37:51
 Re: TIRE SIZE in reply to DAWI, 12-29-2005 14:12:05
I don't know were in Wi you live. But in the southern part I live the local puller rules are under 5000 pounds max size is 14.9 - 28 .
dctom
12-29-2005 17:00:29
i used 16.9x26, much easier to find as most combines used them,
DAWI
12-30-2005 06:44:39
 Re: TIRE SIZE in reply to dctom, 12-29-2005 17:00:29
dctom does the 16.9-26 raise the back end on your vac and what did you run for the front tires. Do you think it takes a lot of power to run the 16.9
dctom
12-30-2005 09:01:34
 Re: TIRE SIZE in reply to DAWI, 12-30-2005 06:44:39
16.9x26 are bigger around than 28's and if you have a combine 201 you have plenty of power tom
DSWI
12-30-2005 09:05:13
 DCTOM in reply to dctom, 12-30-2005 09:01:34
Tom did you stay with the regular 15 inch front tires or did you go with a smaller size if you went with a smaller size what hubs did you use to convert it
