450LP head and 4 1/8 firecraters
JakeF
12-31-2005 20:18:22
Can I run my 4 1/8 firecraters with a 450LP head on a Super M. Thanks, Jake
TONY J
12-31-2005 23:41:42
 Re: 450LP head and 4 1/8 firecraters in reply to JakeF, 12-31-2005 20:18:22
yes, it makes a nice little setup.
ihpuller400
01-01-2006 17:18:51
 Re: 450LP head and 4 1/8 firecraters in reply to TONY J, 12-31-2005 23:41:42
Yes what tony j said is right it is a nice little set up it is never enought you need a stroker!!!!! !
JakeF
01-01-2006 19:07:43
 Re: 450LP head and 4 1/8 firecraters in reply to ihpuller400, 01-01-2006 17:18:51
Head this year and maybee a stroker next year. What would you reccomend for a stroker bore X stroke and the crank, pistons, cam, and rods by who? Thanks, Jake
ihpuller400
01-02-2006 22:34:30
 Re: 450LP head and 4 1/8 firecraters in reply to JakeF, 01-01-2006 19:07:43
well as far as how much you need what are you runing with think of all the realy good tractors you run with and just add an inch to your crank for every one you think of LOL you can go from 6 inches to seven and 1/2 with vary few problems just a lot more work and $$$$$$$$$$$$$ depending
but M&W gear compony mad a 6inch crank that fit right in with stock rods and no grinding have a shop do an offset grind to six and it will more then likely do the same with maby a few grind here and there with still stock rods and with the head and pistons you alredy talked about and this crank you should git 80-90 HP posibly more or less if you think that will be enought
PS rember carb cam need to also be mad larger
Trkr
01-02-2006 19:53:13
Stroke crank to 5 3/4 stroke(1/2),stock rods,M+W pistons #177(4 1/8 bore)179 (4 1/4 bore).Bolt to gether,no grinding.326 cid with 4 1/4 bore.
Trkr
01-03-2006 06:32:40
 Re: 450LP head and 4 1/8 firecraters in reply to Trkr, 01-02-2006 19:53:13
M W Crank is 5 3/4 not 6 .I bought one brand new and still running it in my 450.
