Performance manifolds and carbs
Jared C.
03-14-2002 12:47:26
Does anyone know where I can get a manifold extrudahoned or acid ported? Mine is pretty restricted as stock and I think it will be hurting me on power. Also, how about a good, reliable place to have a carb modified for pulling. Even better, what exactly are these guys doing to modify these carbs. I cant believe its much. You can about count all the parts on one hand. I work in a machine shop so I can probably do it myself. Thanks to anyone who can help.
Dave N
03-15-2002 04:48:30
 Re: performance manifolds and carbs in reply to Jared C., 03-14-2002 12:47:26
Extrude honing is very expensive I priced a manifold and they quoted me 600.00 if you want to pay that much I can find the phone number of the place. Dave
carb expert
03-14-2002 18:45:03
Denny's carb shop is the place to go.
G-MAN
03-14-2002 19:26:38
 Re: Re: performance manifolds and carbs in reply to carb expert, 03-14-2002 18:45:03
So how much are you being paid to say that? If you're just trying to start more b.s., give it up.
It's not worth anyones time.
tim
03-14-2002 14:36:05
What kind of motor?
Jared C.
03-14-2002 17:59:47
 Re: Re: performance manifolds and carbs in reply to tim, 03-14-2002 14:36:05
F162 Continental, not quite stock anymore.
Slo
03-14-2002 19:53:20
 Re: Re: Re: performance manifolds and carbs in reply to Jared C., 03-14-2002 17:59:47
If that's the Red Seal Continental, Motec just did one for me for a MH 30 with a 162 Red Seal.
Good work, very reasonable rates. Happy again with Motec.
Jared C.
03-15-2002 06:11:18
 Re: Re: Re: Re: performance manifolds and carbs in reply to Slo, 03-14-2002 19:53:20
How can I get hold of this Motec? Do you have a phone number or website for them?
Slo
03-15-2002 15:22:56
 Re: Re: Re: Re: Re: performance manifolds and carbs in reply to Jared C., 03-15-2002 06:11:18
765 963 6628, ask for Matt. Heckuva nice guy too.
tim
03-14-2002 19:30:58
Not familiar with that. You can remove an 88 oliver gas intake and take an 88 deisel intake, turn it upside down, find any agricultural carb,
bolt it on and make a world of differance. If you look hard enough you can find bigger intakes that will bolt right on and if you have the cubes and cam to handle it then it is real cheap power and is still legal by a lot of rules.
Otherwise to make any noticable differance you have to cut the runner in to and open the plenium
from both directions. Tapering the intake from large at the carb to something smaller at the head will speed the airflow up as it gets to the head. Then weld it back togather.
Dan
03-14-2002 14:16:49
On the carbs for my ih's I generally clean up this inside and polish and I also increase the size of the venturi. They have made a difference on my tractors
carb expert
03-14-2002 18:46:08
 Re: Re: performance manifolds and carbs in reply to Dan, 03-14-2002 14:16:49
Denny's Carb Shop is the place to go
Dick
03-14-2002 19:26:23
 Re: Re: Re: performance manifolds and carbs in reply to carb expert, 03-14-2002 18:46:08
Denny's is the last place to go
