G-Cam Shaft- gear marks
JDTRUBLE
01-09-2006 10:40:42
looking for how to get the cam shaft and the gear aligned correctly, is there a timing mark on the cam shaft that would line up with the gear? Thanks
Drew
01-09-2006 16:55:59
 Re: G-Cam Shaft- gear marks in reply to JDTRUBLE, 01-09-2006 10:40:42
I thought the bolt pattern was set up so that it would only bolt up one way.
G/MAN
01-10-2006 13:26:55
 Re: G-Cam Shaft- gear marks in reply to Drew, 01-09-2006 16:55:59
I don't believe so. The holes are equally spaced, which is why the manuals recommend marking the camshaft and gear upon disassembly.
G/MAN
01-09-2006 10:44:42
Not unless someone put one there when the gear was removed.
