Flywheel weight?
Troy
03-16-2002 16:33:39
Would a flywheel that weighes 3 lbs. more than my stock one give a noticeable difference in performance? Its on a 4cyl. 4-3/8 stroke. Thanks
tim
03-16-2002 20:49:57
 Re: flywheel weight? in reply to Troy, 03-16-2002 16:33:39
You wouldn't notice any thing at three pounds.
randy hall
03-16-2002 19:42:32
it would if you were pulling a hay baler or running a silo blower. it takes power to turn the weight of the flywheel. i took 25# off of mine.
Troy
03-16-2002 20:12:01
 Re: Re: flywheel weight? in reply to randy hall, 03-16-2002 19:42:32
I thought it would increase lugging power? This tractor will never see over 2200rpm.
G Taylor
03-16-2002 20:16:50
 Re: Re: Re: flywheel weight? in reply to Troy, 03-16-2002 20:12:01
A heavier flywheel makes the engine output smoother. It also allows lugging to a lower rpm before stalling. The heavy wheel also slows acceleration & de-acceleration.
