Help Carb?
Mike B
03-16-2002 20:58:35
What carb will feed a 400+ci. 77 oliver? Thanks for any help.
Brad
03-18-2002 12:17:10
 Re: Help Carb? in reply to Mike B, 03-16-2002 20:58:35
what kind of rpm's are you turning?
Mike B
03-19-2002 08:28:25
 Re: Re: Help Carb? in reply to Brad, 03-18-2002 12:17:10
Will be running 2100-2500rpm. depending on where and what class I pull Thanks for any help.
tim
03-19-2002 19:41:15
 Re: Re: Re: Help Carb? in reply to Mike B, 03-19-2002 08:28:25
You will need to a carb that will flow at least 260 to 270 cfm.
tim
03-19-2002 19:18:20
Obviously you are not going to run a 77 intake....
Right? If you do, nothing is going to feed it. The motor will suck a lot though.
