8 bolt to 9 bolt adapter any such a thing?
m. jamison
01-22-2006 18:46:34
I have an allis with 8 bolt pattern and need to go to a 9 bolt pattern without welding on permanent plates to the tractor. Because i have 3 sets of wheel and tires that i use regular that are 8 bolt pattern and i hate to convert a set of perfect 9 bolts to 8's. if there is such an adapter could you tell me where i can get one thanks.
Kurt-Allis Puller
01-23-2006 20:17:23
 Re: 8 bolt to 9 bolt adapter any such a thing? in reply to m. jamison, 01-22-2006 18:46:34
For close to the money you"ll have in adaptors you can buy 8 bolt 38" centers and they look nice.
m.jamison
01-23-2006 17:42:32
I called the guy in the hook mag, and he is going to build me a set for 125$. thanks for the response.
Ohio WD Puller
01-23-2006 05:40:49
I have a guy that makes them for me at 250 dollars a set. That comes with the 8 bolts counter sunk and the 9 bolts drilled and tapped for 9/16 fine thread. If interested call me at 419 295 4592.
Ohio WD Puller
medberry's
01-22-2006 20:26:50
Jamison i can probably get you a set of custom bolt on adapters made, my first set was on my WC going from 6 to 8 and they work great. Give me a call 724-376-2828. Located in western PA.
ChadS
01-22-2006 19:10:13
There was a fella that was advertizing those adapter plates for the AC tractors in the HOOK magazine in the classifieds. Would be your best bet. Hope this helps,, Chad
